rename layer delete ($nn)
daken
  • Active Member
  • 32 replies
Is there a way to bulk delete all the number in the layer name with rename layer feature?
Best answer by y_toku
Hi ​@daken
If you want to remove only digits, how about  \d+ for Match field? The underscores still remain in this case.
Alternatively, if you want to remove everything before names like "apple" (including any leading underscores and digits), try this pattern:
  • Match field: ^[_]*\d+[_]*
I hope this works!
Toku
Ondrej_Pavlicek
Hi there,
You should be able to use $`-app' to remove the number prefix.
Hope it helps!
daken
  • Active Member
  • 32 replies
  • May 26, 2025
Ondrej_Pavlicek wrote:
Hi there,
Hope it helps!
$` It does not work?
I would like to remain the current name and delete the number
  • 2545 replies
  • May 27, 2025
Hi ​@daken
I hope this works!
Toku
daken
  • Active Member
  • 32 replies
  • July 5, 2025
y_toku wrote:
Hi ​@daken
I hope this works!
Toku
its work
thanks a lot
