Anders_Lund
Oct 4, 2024 10:57 AM UTC
remove MUI Select values in prototype
Hi, I’ve duplicated the MUI Appfarm kit to my own and made some changes for internal use, I’ve noticed that when I use the select in my prototypes and if you click the select it shows three menu items. Seems like this is added with react code on the component, the code is visible if you change to dev mode in Figma but not editable. Is it possible to remove this code to not have the default values show or maybe create a component property out of them so that it is easy to change the values in the side menu in Figma?
