Eric_Wright
Jan 22, 2021 6:40 PM UTC
Publishing a plugin update with SSO not two-factor
I’m trying to publish an bugfix update of our plugin, and the Publish plugin window displays the error “Please enable two-factor authentication to publish this plugin”. Our company uses SSO, and does not have two-factor enabled.
The support page at https://help.figma.com/hc/en-us/articles/360042293394-Publish-a-plugin-to-the-Community says
You need to have two-factor authentication enabled to publish plugins, including publishing updates to existing plugins. You won’t need to use two-factor authentication if you sign in to Figma via SAML SSO or Google SSO.
But I can’t find any further information about how to publish the update without enabling two-factor.
GlebSolution
Power Member
Jan 23, 2021 12:30 AM UTC
This sounds like a bug. Reach out to Figma support via support@figma.com or Submit a request – Figma so they can look into this issue with your account.
GlebSolution
Power Member
Eric_Wright
Jan 25, 2021 4:48 PM UTC
Thanks @Gleb - I will.
nico_seekout
Jul 12, 2023 11:02 AM UTC
@Eric_Wright I ran into the same issue and have reached out to support. I’m curious if, in your case, it eventually ended up being resolved without support correcting things on their end.
Alice Works
Apr 7, 2025 8:52 AM UTC
Having the same issue, can you pls fix! 😥
Steven_Bassette
Jul 9, 2025 9:04 PM UTC
Is there a fix to this?  I’m also logged in using SAML SSO, and I created a test widget for internal use only.  I’m not able to publish it because you cannot enable 2FA on SAML SSO accounts.
