Millaray_Campos_Zuniga
May 20, 2022 2:25 AM UTC
Prototype not loading in Google Chrome
Hi guys! I have a problem with my prototype in figma. I just open the prototype in figma and it works fine but when I open it in chrome it doesn’t load. This happens only in Chrome because I have opened it in other web browsers like edge and internet explore and it works perfectly. Can anybody help me?
Gayani_S
Aug 14, 2024 8:19 AM UTC
Hey @Ridge_Anderson, thank you for reaching out!
Can you please try the following troubleshooting steps and let me know if this resolved the issue for you?
Thanks!
Ridge_Anderson
Aug 15, 2024 10:50 PM UTC
I cleared Chrome cache and tried incognito window and enabling OpenGL and nothing worked. I ended up downloading the app and it worked, but we can’t require our clients to do that.
Aug 16, 2024 7:54 AM UTC
@Gayani_S For the past few days, I’ve been having issues with clients due to non-functioning prototypes. It’s taking you a very long time to fix this problem. Do you even have a plan to address this?
Hamza_Ali
Aug 19, 2024 4:43 AM UTC
Sure, here’s a more concise and technical response:
It sounds like Chrome might be having compatibility issues with your Figma prototype. Try loading it in Incognito mode; if it works, a browser extension could be the culprit. Disable extensions one by one to identify the issue. Ensure Chrome is updated, and clear cache and cookies for Figma. If it still doesn’t load, consider resetting Chrome’s settings to default. This should help resolve any conflicts.As i have fixed the same issue for my inasaldiningprices,a reliable source of of mang inasal menu,click here to see
Gayani_S
Aug 19, 2024 8:13 AM UTC
Hey @Ridge_Anderson, thanks for confirming this! This is not the ideal solution, I’d like our technical quality team take a look at this. I’ve submitted a support ticket on your behalf. Your ticket number is #1097305, for reference.
Our support team usually takes up to 24 hours to reply back to emails - tends to be quicker than that in normal circumstances. However, please be aware that we are facing increased contact volume so there might be a delay.
Appreciate your patience in the meantime!
Gayani_S
Aug 19, 2024 8:17 AM UTC
Hey @Jacek_Barwacz, apologies for the issues! It seems like these issues are getting solved for some users when clearing the cookies. Also I am not able to reproduce this issue on my end.
Can you please confirm if you’ve tried all these suggestions solution? If you’re still experience any issues I can get you connected with our technical quality team.
Cyan_Ma
Sep 27, 2024 9:12 PM UTC
Same problem here. I embeded the Figma prototype inside webflow, and it neither load while I’m editing inside webflow nor on the finished and published website. I changed another browser and it can load.
I’m creating a portfolio by embedding the prototype, so all the above solutions cannot work for me because it will be random people who use chrome to view the prototype, and they will not be clearing their browser cookies for that.
Please let me know if I can do anything to fix on my end, and I wish this issue can be solved asap. Thank you!!
Abrorbek_Azizov
Oct 4, 2024 6:34 AM UTC
I have the same problem in Chrome.
Gayani_S
Oct 4, 2024 8:13 AM UTC
Hey @Cyan_Ma and @Abrorbek_Azizov, thank you for reaching out!
Can you please check if you’ve tried the following steps:
  • Clear cache
  • Update to the latest browser version
  • Confirm you have WebGL installed and enabled
  • Check if the same issue occurs in an incognito window or after disabling any running browser extensions?
Please take a look at our Help Center article for more information: How do I configure my browser for Figma?
Thank you in advance!
David_Billings
Oct 15, 2024 5:09 PM UTC
I’m also having this problem in Chrome, even after trying the above steps.
Crome version: 129.0.6668.101
MacOS: 14.6.1 (23G93)
Any ideas?
