Alex_Sweet
Sep 21, 2022 1:29 PM UTC
Problem navigating with arrow keys linearly through screens on prototype
Hi, I believe I’ve exhausted all the existing help articles on this.
I’m having a hard time with something that should be very basic. I have 25 or so screens, the ONLY interaction between them is that the user should be able to click and/or press the arrow key to navigate LINEARLY between them.
Sometimes it works (especially if I go slowly, it works every time). But sometimes it doesn’t, sometimes it inexplicably jumps through sections (pretty much only happens if I press the arrow keys quickly). It appears that if I click through it goes linearly every time without skipping screens. So the problem is only with the arrow keys (which I can’t disable so I need to understand the behavior before handing off to my client).
I’ve adjusted all the artboards. The desired order is Row 1 Left to Right, Row 2 Left to Right (as described in the documentation). All rows have the exact same Y coordinate. All columns have the exact same X coordinate.
I’ve spent hours on this already and this is really basic behavior so I’m not sure why it’s so hard, I want it to act like powerpoint in presentation mode.
Any help is appreciated. I can’t really share the prototype because I’m on NDA.
A.J
Nov 1, 2022 2:40 PM UTC
I don’t know if this is a related topic, but when prototyping tab navigation for web accessibility, we should be able to have some analog of the HTML tabindex= attribute on items, to enable easier keyboard navigation inside screens. (And, if possible, toggle a state on keyboard nav vs mouse pointer events, like showing focus states.)
Mike61
Jan 5, 2023 9:36 AM UTC
I had the same problem, so started to do this by hand and found it very time consuming, then I found Aashrey Sharma’s brilliant Prototyper plugin, Prototyper | Figma Community
  • With the Figma Prototype tab open
  • Run the Prototyper plugin
  • Go to the Link tab
  • Select top-level frames you’d like to navigate in your prototype
  • Select Navigate with Keyboard | Arrow Keys
  • Click Link Frames
Navigation direction and inputs are automatically assigned based on the arrangement of selected elements, so make sure your frames are ordered consecutively and spaced horizontally.
Jairo
Jan 5, 2023 10:11 AM UTC
Along with this answer, i would like to suggest the use of another pluggin called “Protofly”: Protofly | Figma Community
Similarly to prototyper, you select two frames that you want to connect, and it allows you to save and apply interactions in all selections you make.
robin_figma
May 22, 2023 5:24 PM UTC
This thread may help…
robin_figma
May 22, 2023 5:29 PM UTC
Or up vote the solution here…
Alexei
Oct 26, 2023 12:18 AM UTC
Prototyper plugin is a great answer to this issue I experienced as well
David_Koci
Jan 10, 2024 7:47 PM UTC
+1 for me. It is such a pain!
Ariel11
Feb 24, 2025 2:15 PM UTC
I’ve managed to fix, I guess.
  1. Save a version, just in case
  2. Select everything (Ctrl/Cmd + A)
  3. Cut (Ctrl/Cmd + X)
  4. Paste (Ctrl/Cmd + V)
Idk why but seems to fix the arrow key problem without breaking prototype connections.
kw711
May 1, 2025 7:01 PM UTC
This worked for me, thank you!!
