Chaine
Plugin websocket connection issue
  • July 21, 2023
  • 1430 views
I want to use websocket to connect a server, but I can’t connect through ws://, as it’ll show error ‘xxxx loaded from https, the endpoint must be through wss’ , so I changed the url to wss:// and set up the port.
But when I added the domain wss://xxxxx.com to the manifest.json, and tried to connect to wss://xxxxx.com:[port], it showed a new error 'Please add “wss://xxxxx.com:[port]” to the networkAccess > allowedDomains field in your manifest.json
Then I did what it told me to, and got ‘manifest error’ because “wss://xxxxx.com:[port]” is not a valid url 🫠
Currently the work around is to set allowedDomains to “*”, but I want to use constraints to domains. So how can I set up a right domain for the url with a port?
Best answer by Akbar_Mirza
Hey @Chaine, are you still experiencing this issue? We’ve made a number of changes that should fix this use case - but let me know if you’re still having issues.
Akbar_Mirza
