DanDoesDesign
Apr 17, 2025 2:47 PM UTC
Plugin : Non Null Origin iFrame
Hey there, I’m looking for help setting up the UI for a Figma plugin.
I am using a non-null origin, and testing the code using “https://www.google.com”
figma.showUI(
`<script>
window.location.href = "https://www.google.com";
console.log(window.origin); //null
</script>`,
{ height: 600, width: 400 }
I’ve included google in the manifest as an allowed domain.
  "networkAccess": {
"allowedDomains": ["https://www.google.com",
"https://*.google.com"
"reasoning" : "For testing purposes",
"devAllowedDomains": [
"https://wwww.google.com",
All I see in the plugin window is a white box. The console isn’t throwing any syntax or permission errors.
Does anyone have a suggested fix? Is there something “basic” that I’m missing? (like, not testing showUI with google)
Thank you for your time.
reynaldi
Apr 24, 2025 10:28 AM UTC
Your snippet for loading a non-null origin is already correct, by using the window.location.href. However, it’s Google that is preventing you from loading it in an iframe.
Google is using the `X-Frame-Options: SAMEORIGIN` header, which means it can only be loaded inside an iframe in a same origin (meaning only google.com can load an iframe of google.com).
Just try it immediately using your actual UI, and you should be good.
