Nov 26, 2023 2:26 PM UTC
Paragraph spacing do not work
Hello, i have a big problem !
When i’m changing my paragraph spacing in my text style, it doesn’t change my text… In my example, you can see i set the paragraph spacing to 91 (huge spacing) but i still have a kind of 20.
It’s working for other properties. I’ve restart Figma but still have the issue.
Please help me, thank you
Nov 27, 2023 6:34 AM UTC
Hi there,
Thanks for flagging. I will check this behavior with our internal team and will get back to you once I have any updates.
Toku
Nov 28, 2023 12:26 AM UTC
Hi there,
Our engineering team confirmed it was a bug, and they fixed it. Once you reload the tab, it should be fixed. I confirmed it on my end, but if you keep seeing the issue, please feel free to let us know. Thanks again for flagging!
Toku
Juliana_Vimmer
Dec 28, 2023 7:34 PM UTC
Im having the same problem, the paragraph spacing simply does not compute
Iberedem_Harry
Jan 8, 2024 6:44 AM UTC
Yeah i had the same problem except what you have to space should actually have a paragraph in it. so you should use ‘Enter’ for a next line then try the feature again… 😉
Feb 6, 2024 8:14 AM UTC
Oh! Thank you for your tips!!
Aditi_Sharma1
May 6, 2024 4:13 PM UTC
I have the same issue, I came here to find a solution, but turns out its a bug?
Bas_Schellekens
May 20, 2024 6:16 PM UTC
got the same problem, seems bugged still
May 23, 2024 1:09 AM UTC
Hi @Aditi_Sharma1 @Bas_Schellekens ,
Thanks for reaching out. Could you share the screenshots or screen recording so we can understand the issue correctly? Also, your working environment such as OS, browser etc would be helpful!
I tested it on my end and it looks working properly at the moment.
Thanks!
Toku
Laura_Elizabeth
Jun 24, 2024 12:23 PM UTC
Hi, I’m having the same problem (I’m on the latest version of Figma). I have noticed that it doesn’t work if there are multiple paragraph styles in the same text box.
See this video: https://vimeo.com/966629322/5beebad5e0?share=copy
I’m on Mac OS if that helps.
Jun 25, 2024 1:57 AM UTC
Hi there,
Thanks for sharing the details! It could be a bug. Could you submit a bug report detailing the steps that led to this issue? You can do so by following the link:
Figma Learn - Help Center
Thanks again!
Toku
