Navigate to - set to none by default
Hi guys.
I noticed that when I’m in prototype mode, I have screen A and screen B.
On the screen A, I press on the + button to generate an arrow link going to to screen B.
By default the link action is [Drag to] [Navigate to: screen B].
When I switch [Drag to] to [Click on] I’m expecting screen B staying selected by default in the [Navigate to] dropdown. Instead the screen selected resets to ‘none’ and I have to select the screen manually from the [Navigate to] drop down.
Not very user friendly and time consuming indeed if I have 100 screens in a document.
Do you guys have please a suggestion on how to keep the screen B selected when I change the action type?
Hi there,
Thanks for the post. I hope to replicate the behavior, would you be able to share the screen recording? If you can share the file link, that would be helpful too. Would you be able to share the file link with access to support-share@figma.com? It won’t affect your billing. I hope I can investigate it further.
Toku
