Tobias_Fuchsberger
Dec 20, 2023 6:39 PM UTC
Major issues with component instances not being rendered correctly
Recently I have major issues with component instances not being rendered correctly.
Every other component instance is rendered incorrectly upon opening the file. To fix the problem I have to click into every instance, which seems to correctify it but is a major painpoint since I have hundreds or thousends of instances all over different files. This means I have no idea if the handoff to the programmer is actually correct since I don’t know which instances are incorrect or if they are rendered properly or not on the different devices.
tank666
Dec 20, 2023 7:23 PM UTC
Please also submit a bug report.
Jan 29, 2024 9:28 PM UTC
I’ve had the same issue and it’s very frustrating.
Tobias_Fuchsberger
Jan 30, 2024 1:09 PM UTC
Sorry, haven’t seen your response.
I’ve reached out through the in-app bug reporting interface and they’ve suggested the same thing to fix the issue.
It worked perfectly well for me. The issue returns every once in a while, but now at least I don’t have to fix all the errors manually.
Thanks for your response!
Nino_Silva
Feb 16, 2024 5:29 PM UTC
My team has been having the same issue, thank you for sharing.
ninja_von_oertzen1
May 2, 2024 1:18 PM UTC
Had the same issue, rendering complex prototypes useless because nested components would not display correctly. Double-clicking on individual instances temporarily “fixed” the issue one by one, but this method would be untenable for hundreds of instances.
Thank you for suggesting Regenerate all instances (slow) from the Quick Actions panel. It seems to have fixed all instances, but I am still verifying that this step has carried over manual overrides that were set during fast iterations in the layout process.
Aug 9, 2024 7:21 PM UTC
I have the same problem. This is a major flaw that needs to be fixed if we are to trust Figma. Otherwise, the use of components is useless if we can’t trust that what developers are looking at is what we designed.
Tascha
Aug 15, 2024 3:50 PM UTC
Chiming in here; happens to me too and is very annoying 😥
Sad to see this issue has been occurring so long already…
Hassam_Ali
Sep 18, 2024 2:56 PM UTC
We have a design system and multiple project files, but one of the instances isn’t rendering correctly in a particular file. It’s really weird and frustrating. I can’t create a new file because there are too many flows and pages inside it, and I need to use this one primary variant on almost every page. The strange thing is, everything works well locally and in other design files, but for some reason, it’s not rendering properly in this specific file.
Matteo_Sgambato
Sep 26, 2024 2:22 AM UTC
My team has the same issue. Seems to happen when using text variables to automatically switch a property using modes.
Please fix it, it’s very frustrating 😦
Faezeh_Mashmool
Oct 7, 2024 12:58 PM UTC
My team have faced the same issue. How can we fix it? according to replies I got that if we use Regenerate all instances (slow) all of the instances will be set to default main component. right?
