Tobias_Fuchsberger
Dec 20, 2023 6:39 PM UTC
Major issues with component instances not being rendered correctly
Recently I have major issues with component instances not being rendered correctly.
Every other component instance is rendered incorrectly upon opening the file. To fix the problem I have to click into every instance, which seems to correctify it but is a major painpoint since I have hundreds or thousends of instances all over different files. This means I have no idea if the handoff to the programmer is actually correct since I don’t know which instances are incorrect or if they are rendered properly or not on the different devices.
Oct 8, 2024 5:49 AM UTC
Hi there,
If the instances are not rendered correctly, we suggest “Regenerate all instances (slow)”. It is like refreshing/updating as if you were clicking into a layer, but does so automatically on all instances in the file. Sometimes double clicking can fix this kind of issue. So, could you give it a try?
Also, please submit a bug report detailing the steps that led to this issue so our team can investigate it. You can do so by following the link:
Figma Learn - Help Center
Toku
Ida_Melank2
Oct 17, 2024 10:48 PM UTC
I have the same issues as yours. Did the “Regenerate all instances” action preserve manual overrides?
