Joanna_Majewska
Dec 17, 2024 11:10 AM UTC
Issue with padding when replacing a component in a slot
I’m running into an issue with a component that uses a slot. When I replace the slot content with an instance of a different component, the padding of the original slot component is preserved instead of inheriting the padding from the new component.
I expected the replaced component to behave with its own padding settings, but it seems the slot’s container enforces its own padding.
Is there a way to make the new component respect its own padding instead of inheriting it from the slot container?
Any suggestions or workarounds would be greatly appreciated!
Pavel_Kiselev
Power Member
Dec 17, 2024 1:31 PM UTC
It seems like the slot itself has padding overrides so when you swap it these overrides persist. I would make sure that my slot placeholder does not have ANY overrides to prevent unwanted behaviour when swapping instances
