Oct 24, 2023 6:46 AM UTC
Issue with instance component
Hello Guys,
Please look into this file i have designed with component and also taken the instance of it.
The main issue is the sidebar is working fine in main Frame but the instance sidebar is not working in the second frame which is a copy of the main component.
If anyone have idea about it why this is happening will be grateful attached community file below.
Figma
Oct 31, 2023 3:22 AM UTC
Hi there, thanks for waiting! This is unfortunately a feature limitation where swapping instances/changing variants on nested instances keeps the size of the initial instances/variants. However, there’s a workaround! To get the nested instances to resize, you can add auto layout on each variant of those “Title” components. I added some video here so you can follow the steps that I’ve added. I did auto layout (Shift+A). I hope this solves the problem!
Toku
