S.T
Mar 22, 2025 12:51 AM UTC
Is there a way to keep autolayout aligning these sections?
The footer has a component with an arrow that brings the user to the top. Is there a way to have the foot and above section connect while keeping auto auto layout? I know I can use absolute positioning. Just curious is there another way apart from having the above section retain the back to top component.
Thank you
Raphael_M
Power Member
Mar 22, 2025 5:03 AM UTC
set the back to top height's container to 0
S.T
S.TAuthor
Mar 24, 2025 11:44 PM UTC
Thanks for the reply. The back to top component is fine in the footer. I am trying to get the top section to sit flush against the footer behind it but I think this can only be done using absolute positioning?
Raphael_M
Power Member
Mar 25, 2025 12:57 AM UTC
Hi.
I’m trying to understand what you mean. If I’m not mistaken you want the Section Above to be next to the footer, vertically without any space whilst not having any of the sections or components in absolute?
I shown you the trick by putting the height of the back to top into “0”. And yes, if you don’t want any of the height in fixed, it can only be done in absolute position.
S.T
S.TAuthor
Apr 1, 2025 10:59 PM UTC
​@Raphael_M Hello I was able to do it by placing the back to top button and footer in a auto layout and then creating an auto layout for everything and setting it -65. That moved the footer up to connect. Thank you for the help.
