Marcin_Spiewak1
Dec 13, 2023 8:31 PM UTC
Is it possible to use global viewport variables to control different component size?
In a nutshell, I want to control all the different sets of variables I’m building per component (for example, I’m using Header). The problem is if I want to have a global viewport size my component collections do not understand which viewport they are and the boolean does not work.
Right now, if I’m forced to add the same viewport size on each component, this Design Experience is horrible.
Marcin_Spiewak1
Dec 14, 2023 9:00 AM UTC
Maybe extra video of the problem could help - Loom | Free Screen & Video Recording Software | Loom
Gayani_S
Dec 29, 2023 11:54 AM UTC
Hey Marcin, so I’ve asked the team and got the answer that you can use multiple modes across variables collections, you just need to make sure you’ve applied multiple variables to an object/layer first. Then you should be able to change the mode (or modes!) from this menu (“Layers” in the right-hand sidebar). Does this help ?
