EduardB
Is it possible to select all component instances based on a specific component property?
Hello community,
I was wondering if it is possible (either natively or through a plugin some of you may have come across) to select all component instances on a page based on a specific component property?
For example, suppose I have a button component with different "size" variants. One size property is called "desktop" and the other is called "mobile". I want to select only the instances with the "desktop" property.
How would I go about doing this? I couldn't find any specific plugin on my own that could help me do this, so I thought I would ask here since someone else may have come across this specific need and solved it.
johntk22
you have to use the Select Similar plugin
Dennis_N
Power Member
January 14, 2025
I’m curious what’s your goal once you have these components selected.
EduardB
EduardBAuthor
I'm working from an existing comprehensive design system and want to see which specific variants of a component I've used and how often. This is my main use case at the moment, although I can think of others.
Maya4
I have the same need. I would like to select a certain component with a specific color variant so I can swap it out for a component a different library.
Currently, the “Select Matching Layers” does not discriminate between the various properties of a component/its instance. See below: I am only wanting to select the instances with a yellow arrow, but it selects all arrows.
