Hello, I am making a prototype of an interactive map with property lots. Each lot is a different vector shape as a component and they press up right along side of each other in the prototype. I created a hover state for each, but unfortunately, the hover is activated anywhere within the larger component frame, not just within the vector shape as I had hoped because of the overlap. This means that multiple shapes are in a hover state at the same time. I also wanted to make them clickable but I believe this will also be a problem as now the frame will be clickable rather than just the vector shape… Is it possible to either make the component frame the same shape as the vector rather than a rectangle? Or is there a different approach I should be taking?
Irregular vector shape as component - Can I remove or reshape the component frame?
