Aug 22, 2023 11:24 AM UTC
Interaction doesn´t show up in preview but exists in prototype
I´m creating a prototype for a touch-display, and the user can switch between frames and interact with the information.
In the prototype editor, I´ve connected all the nodes correctly, made sure to add the right settings (click on > navigate to > …). It should all work, hypothetically.
But when I preview the prototype (the play button in the upper right corner), some of my interactions don´t seem to show up. The icon that I connected the interaction from doesn´t even show up as a clickeable shape. Does anyone know why this could be and how I can fix it?
It´s only the icon that doesn´t work, unfortunately, it´s on nearly every frame so that´s a bit of a bummer. I´ve checked, and it´s not a component either, just a normal shape.
Aug 7, 2024 2:45 PM UTC
Did you get the solution? I’m experiencing the same thing.
Aug 8, 2024 3:04 AM UTC
Hi there,
Do you see any hidden frames around that icons? If possible, would you be able to share the file link with access to support-share@figma.com? It won’t affect your billing. I hope I can investigate it further.
Toku
