importVariableByKeyAsync returning local variable
  • December 12, 2024
  • 4 replies
  • 28 views
Sergey_Dubina
I’m trying to use importVariableByKeyAsync method: importVariableByKeyAsync | Plugin API.
It’s described as method for getting variable from published library. But I’m getting only local variable
tank666
  • 4873 replies
  • December 12, 2024
Could you please add a detailed description? This method imports a remote variable from a library.
Sergey_Dubina
  • December 13, 2024
My goal is to compare local and published variables. Is there any other way to do this if method importVariableByKeyAsync doesn’t match my needs?
Sergey_Dubina
  • December 13, 2024
I published my variable to library. Then I changed the same variable locally. When I’m calling importVariableByKeyAsync, I expect to get variable stored in published library, but I get local variable
tank666
  • 4873 replies
  • December 16, 2024
It looks like you are running the plugin and using this method in the same file where this variable is published. Instead, you should have run the plugin in a different file (not the library file where this variable is published). That is, get a local variable in a library file, then open another file and import that variable.
Also consider using REST API if your plan allows it:
https://www.figma.com/developers/api#variables
