How to turn a stroke into a boolean property of my component?
  • May 31, 2025
  • 87 views
Pierre Trochu
Hello,
i’ve created a simple button, with text, padding and autolayout. I’ve turned it into a component. I now want to make the stroke a property for all the variants, that i can turn on and off with a boolean.
However, there is no diamond icon next to the stroke in the right hand panel, so i cannot figure out how to tie it to a prooperty. Is it because the stroke is not a nested item? .
Derek_Avila_P
You can add a rectangle shape to your autolayout frame, set its position to “Ignore autolayout”, manually resize it to the entire autolayout size (you could also use the plugin “Resize to Frame” → “Both” and set its constrains to “Left+Right” and “Top+Bottom” then asign this layer visibility to a boolean property.
