How to open an illustrator file?
  • November 29, 2023
  • 4 replies
  • 4413 views
Hi, how to open an illustrator file or image in Figma?
unfortunately, the drag option isn’t working.
Best answer by Celine_
Hey Mustafa,
At this time we don’t support a direct file import from AI to Figma. As a workaround, we recommend you to export assets as SVG.
One important thing to note about this is that not everything may import into Figma correctly if at all, as SVG code is handled differently between the two programs.
You can find more information in our article how to import SVG to Figma here: https://help.figma.com/hc/en-us/articles/360040030374-Copy-assets-between-design-tools
  • 3652 replies
  • November 30, 2023
Hey Mustafa,
Kevin_Johnsun
Any update on this?
is there any workaround for importing illustrator files without relying on Illustrator itself to export as SVG?
Fay_Nunez
Check out this plugin, It lets you import illustrator into Figma without needing illustrator at all.
Figma
Kevin_Johnsun
tnx @Fay_Nunez for sharing, this is awesome 👍
