NathanC
Aug 2, 2022 10:04 PM UTC
How to change direction of smart animation size change?
Hi, not sure how to figure this one out. I have a circle that I want to expand on hover, but when I increase the size in the direction I want, it does not go in that direction.
I know it’s possible as I’ve seen similar stuff and it’s a pretty basic interaction, such as expanding circles for heart/favourite micro-interactions.
Prototype current example: https://www.figma.com/proto/yFy1wCYfhMkC3lxOjz0HNN/Untitled?page-id=0%3A1&node-id=5%3A36 - In this example, I want the circle to finish inside of the rectangle container with the image.
Any help would be appreciated 🙂
Dennis_N
Power Member
Aug 4, 2022 2:28 PM UTC
Simply by it’s position within it’s container/frame:
I hope this helps.
Kaisin_Li
Dec 14, 2023 9:11 PM UTC
Not sure if this is closed, but I’m having the same problem.
I was trying to align both variants on the upper right corner, but it expands from the upper left corner every time
Mr_elad
Feb 25, 2024 1:52 PM UTC
Hey guys, so i had the same problem and I’ve managed to fix it.
here is how
Its all about the bounding box!
Your animation direction is determined by your bounding box, to change your bounding box you hover over the resize lines than hold CTRL/CMND and drag out than you can hold shift for an even size.
after you’ve changed the compument bounding box you can change the actual size of the shape within the component. let me add some picture so you’ll see the reference
Please let me know if it helped and if you need more help 🙂
cd11
Nov 25, 2024 2:26 AM UTC
tysm you are a lifesaver!!
