How do I enable DEV mode
  • February 13, 2024
  • 18 replies
  • 40990 views
My developer requested dev mode, I received an request and on screen accepted it and was told it would be $12. My developer still can’t see everything, the inspect panel is just gone. I can’t see what dev is even offering here?
Best answer by dennsi
Some more questions for you:
Does the file belong to a different team?
What are the settings under the “share” Button in the top right corner?
dennsi
February 13, 2024
I am assuming your team is on a Professional plan?
Go to admin view of your Figma Team, go to Members and check if your Developer is a member of your team and has full access in the “Design seat” column of the Member view table. Also, inside design files the Dev-Mode Slider in the upper right corner needs to be checked (it turns green when it is active). Also you could just press Shift + D.
February 13, 2024
Hi, I’m on the Organizational Plan - do I need to now change plans too?
He is on full access in design.
Dev mode is on, and I can’t see anything even as the owner of the organization, other than my inspector is missing.
dennsi
February 14, 2024
As far as I know, Organization plan offers dedicated Dev-Seats.
What you describe seems weird… Could you share a screensharing of being inside a design file, enabling Dev-Mode and clicking on an element to inspect?
February 14, 2024
As you can see the banner on the top wants me to get permissions for dev mode.
Interestingly if I create a new file i can see dev mode perfectly
February 14, 2024
This is with me holding onto the arrow (to try inspect)
dennsi
dennsiSolution
February 14, 2024
February 15, 2024
Thanks! it will work for me
February 15, 2024
This was the solution! It wasn’t in my organization’s team folder. Thanks so much for your help. 😀
dennsi
February 15, 2024
Great! Feel free to mark the post as the solution 🙂
February 15, 2024
👍 It’s worked
