Daniel_Kalman
December 1, 2022
How do i change instance property with the setProperty function?
  • December 1, 2022
  • 1033 views
I’m trying to set the instance property by calling
setProperty({Icon#46:0 : 'key of desired instance'})
but i get
Property value is incompatible with component property type
Is there anything different with setProperty when you swap instances (instead of a boolean or variants)?
tank666
December 1, 2022
Most likely you mean setProperties(obj).
Are you sure the “Icon#46:0” property is of type “INSTANCE_SWAP”?
Daniel_Kalman
December 2, 2022
Yes yes.
Turns out you need to pass id instead of key here. Took me a minute
Domenico_Flauto1
October 11, 2023
Hey @Daniel_Kalman how did you solve this?
I am trying to change instance of a property (same as screenshot below) to one of preferred values, but can’t find the right syntax anywhere. I am trying
instance.setProperties({
  ["Icon#1512:2"]: "key or id or name"
but I am also getting Error: in setProperties: Property value is incompatible with component property type
tried id, but maybe I am not getting it right? how do I get the id of the preferred values?
