How can I turn an Instance into a Component again?
  • July 5, 2024
  • 319 views
Hi! I was wondering if there is a solution for this: I have an Instance with 5 properties. The Main Component of this Instance is missing. How do I turn the Instance into a main Comp again without (!) loosing the properties. Of course I can just click on “create component” but that will just nest the instance in a sub-layer (and by that the properties of the redone Main Comp will not show the properties in the Prop Panel) Thanks!
Vishal_Ramawat
July 5, 2024
When you select any instance with deleted (missing) component, you see a CTA on right panel to Restore the component.
MoteleAuthor
Thanks for your reply!
If I restore the Comp the instance will appear within the restored Main Comp (nested).
Because the Instance with the properties is now nested within the restored Main Comp, I can’t see the Properties for the restored Comp. Only if I select the nested Instance within the restored Comp. I would like to see the Properties as soon as I select the restored Comp. Hope this is clear, or do I think to complicated !?
MoteleAuthor
The Original Main Comp is in an external Library btw. I copied it to a new Design File in a different Team which turns it automatically into an instance. Maybe thats the reason why it cant be restored…?
