help me to learn this.
  • October 17, 2024
  • 11 views
DOOKDIK
I just designed it for the first time. What do you guys think about this pop-up? And should I improve it? Please help me.
rwb_marns
Hi DOOKDIK,
  1. Avoid bold fonts for labels
  2. Field labels’ font size should be smaller than your value font size
    e.g. label: 12px; value: 14px;
  3. Set your Fields to 40px height
  4. Reduce your border-radius to at least maximum of 10px
  5. Avoid using drop-shadows
  6. If you want to have your Fields with icons, then it should be consistent to all Fields
  7. Set uniform padding to both ends (left and right)
  8. Remove footer background
  9. Set padding the same with #7
  10. Set CTA’s spacing same with #7
  11. CTA’s border-radius should be the same with your Fields
  12. Detach your popover from your Filter component
Try to implement this and let see what will be the outcome. But before that, save the your current design and compare it with the new one.
