Grabbing colors from figma libraries (colors from both Styles & Variables) via plugin API possible?
  • January 25, 2025
  • 191 views
jkvx
I’m doing some plugin development and have a figma document that has a couple libraries added to the file, and these libraries contain both variables and styles with different color values. I am trying to access the color values for all these variables and styles from both libraries programmatically via the plugin API.
Ex:
Is this even possible currently? Or is there any workaround to access the color values associated with variables & styles from libraries associated with your document?
I know the plugin has a teamLibrary API designed to work with library files, but I only see two available methods (getAvailableLibraryVariableCollectionsAsync and getVariablesInLibraryCollectionAsync), and I don’t think either of these are able to give me the color values associated with the variables in the library. And in addition, neither of these methods work with Styles in the libraries (only variables).
Any input is appreciated, thanks!
Ashutosh Verma
yes you can import local variables and styles , you can use following APIs
getLocalVariables() → to import local variable
getLocalTextStyles() → to import local effect styles
getLocalEffectStyles() → to import local text styles
getLocalGridStyles() → to import local grid styles
getLocalColorStyles() → to import local grid styles
