Figma to wordpress
Crypto_Merlin
Capture d’écran (216)
Hello everyone, I have a problem for import file Figma to wordpress, what is the problem and someone have a solution for that ?
After generate token and copy paste the Url Figma file in Wordpress is dont work.
  • May 11, 2024
Contact the developer of the converter you are using.
Hello,
Thank you for trying my WordPress plugin. There is a Figma file url changes that I’m not aware which causing this error and it should have been fixed. This WordPress plugin have the Figma plugin companion:
https://www.figma.com/community/plugin/1259821200791182652/figma-to-wordpress-block
I recomended to use the Figma plugin instead because I rarely update the WordPress plugin. The Figma plugin have a better result and it’s more flexible.
