Wolle
Dropdown menu disappears when leaving the hover area (which it should not)
Here is my problem:
I have a component (for reuse). This component has a background that casts a clear shadow on hover. To prevent objects that also have a shadow from inheriting it (because that looks awful), the background is only used to display the shadow on hover. All other elements are arranged in their own group/box.
Above the background component is a box with another icon button that is only visible on hover. On click, the dropdown of this icon button is then expanded. I make it visible and invisible again with a Boolean String on Hover. Note: Even Mouse Enter or Mouse Leave doesn’t fix my problem.
When I move the mouse pointer out of the parent box, the icon button also disappears. Because the dropdown goes beyond the box and if I select an entry in the select box with the mouse, I leave the parent box and the dropdown disappears.
I have summarized the conditions in a picture because unfortunately I am not allowed to share the prototype.
Is there perhaps a simple solution to get around this? Because this seems to me to be a very classic scenario in a UI?
Thank you.
Wolle
WolleSolution
I have now been able to solve it myself.
Mouse Leave did not work. But Mouse Leave AND Add Delay solves the problem. You should read dialogs carefully 😉
Bildschirmfoto 2024-05-15 um 09.05.11
Wolle
WolleAuthorSolution
Hey @Wolle,
Glad to hear you have found a fix! Thank you for sharing it.
I have marked as solved for your topic 🙂
