Wolle
Jun 28, 2024 7:53 AM UTC
Dropdown inherits shadow from parent element - which it should not
Unfortunately I have not found a solution.
The following situation: I have a header box with a box-shadow. In this header box is a user avatar icon that opens a dropdown menu with further options for the user when clicked. This dropdown also has its OWN box shadow. But now the box-shadow is inherited from the header and the box-shadow of the dropdown looks horribly bad.
How can I prevent this WITHOUT positioning the dropdown absolutely and placing it outside the header box?
It seems to me to be a pretty standard case that there are dropdowns within boxes that also have a shadow. So I don’t understand why you can’t set this separately.
In the example shown here you can see that the shadow is displayed correctly if the user icon is placed outside the header box. Which of course cannot be a solution.
Thank you for your attention! 🙂
Toby_Magrath1
Jun 29, 2024 12:24 AM UTC
Is this for making a prototype? If so I wouldn’t build the flyout into the header component but keep the flyout it’s own component that can be opened via the OnClick > Open Overlay and Manually position the flyout menu VS nesting in a component.
Marian_Brchan
Jun 28, 2024 10:22 AM UTC
The easiest solution for you is to use a separate layer that works as a background and shadow for the header.
If you’re using autolayout, you can apply absolute positioning just to this BG element and keep everything else the same.
Wolle
WolleAuthor
Jun 28, 2024 11:22 AM UTC
Thank you! I already had this solution, but I was hoping that I could do without such a workaround. 😀
Toby_Magrath1
Wolle
WolleAuthor
Jun 29, 2024 1:03 PM UTC
Thank you very much!
In this case, this is a solid solution. But what do you do with forms with lots of dropdowns? Normally the dropdown box is part of the component because otherwise you would have to permanently maintain many external boxes.
Toby_Magrath1
Jul 10, 2024 1:39 AM UTC
When I build components for library use I don’t usually include a shadow on the shell element but on the flyout that would appear in an open state of that variant. So a shadow can exist on a nest element and not on the parent. Like this:
Wolle
WolleAuthor
Jul 10, 2024 6:09 AM UTC
Yes, I think this is the usual procedure. In my case, however, the dropdown is in a box that must already have a shadow. It would therefore be good to be able to control such effects separately.
