Pau_Giner
March 25, 2021
Dragging direction options disappear
When setting a transition between two states of an interactive component based on the “drag” event the options to indicate the direction become impossible to select.
Options to select direction are available when the animation type is different than auto-animate. However, those options appear disabled in the menu. so selecting auto-animate makes it impossible to go back to them.
I included a short recording to illustrate this:
Mar-25-2021 09-21-07
I experienced the issue with the Figma app on a Mac.
Michael_Kingery
May 19, 2022
following…
September 11, 2023
Did you get a solution for this yet?
July 18, 2024
I am encountering the same issue. The only workaround I’ve been able to find is to change the interaction type back to “click” and change the animation from smart-animate to “instant.” Then, if I change the interaction type BACK to “drag”, the default selection is “Move-In” again.
But yes, if the animation type ever gets set to “Smart Animate”, the Move-in option will become disabled again. Seems like a bug
