Dev Mode inspect panel differences between access types?
Why does the Dev Mode inspect panel look and function different depending on on a user’s access type (view / Dev Mode only vs edit access)?
What my devs see in Dev Mode (without edit access):
What I see in Dev Mode (with edit access):
As you can see, these look different for some reason. The most troubling for me is that the code syntax added to variables don’t show when the user doesn’t have edit access (which is all of our devs, they don’t need edit access) and so they get no benefit from that code syntax.
As far as I can tell, everywhere that Dev Mode is documented in help.figma.com shows the panel as if the user has edit access and doesn’t show or touch on how it differs if the user does not have edit access. Is this intentional? If so, why and why is it not documented?
