May 28, 2024 9:58 AM UTC
Detach child instance only
Main question: I have a component that utilizes a .base component which contains another component element. When editing the top level variation I want to detach the child component instance within the .base component without detaching the parent component instance. Is this possible?
Supporting Information:
You can see in my image the set up of the .base/card with the “Slot” component at the bottom. Within the “Rotation Progress” component I changed the “Slot” component to the “Progress Bar” component (“slot” component is an interchangeable component to help make more variations within one .base component). Now that I have the “Progress Bar” component within my variant, I want to detach just that child component to make further edits. However, when I try to detach instance on the “Progress Bar” component, it will detach instance from the .base/card parent component as well.
Power Member
May 28, 2024 10:01 AM UTC
No, you can’t, since instances can’t change what they contain. But you can swap it for another instance.
Dustin_Hansen2
Nov 7, 2024 9:46 PM UTC
This is a huge, huge issue and headache and I don’t understand why it’s like this. It feels like a bug.
Power Member
Nov 11, 2024 3:55 AM UTC
Why does it feel like that to you? If you want something like slots you can vote here: Fully Editable Component Instances
