Creating a card with custom icons without creating a variant for each icon
  • May 15, 2024
  • 209 views
Chris_P_UX
Is there a way of creating a card to allow you as the Figma editor to change the icon used without having to create a variant for each icon you want to or may want to use.
I’ve used SketchApp before and you could create a skeleton/shell of a card or whatever you wanted with a placeholder image or fill and then maybe Lorem Ipsum text, when you place the instance/component into your design you could do an override of the icon and/or text by uploading a PNG or SVG into the component without having to update the master so you could experiment with different icons without having create a component or variant for each icon.
Is that override option available in Figma or is it all handled using instances from a asset library or team library.
Sorry, this might be a basic question for you seasoned Figma users, but SketchApp seemed to handle reusable components/instances a lot easier.
Screenshot 2024-05-16 101633
Amrul_Haqqi
So basically you want to make a reusable component for a card, that each card instance you apply into your design might have a different icon and you want to have access to set their icon individually.
actually I have a simple way to that and you can follow this step by step:
  1. First thing you should define and put all the icons you want into Figma
  2. Make all the icons as a component set, then you may want to set the name for each icons to help you in the future.
  3. Let’s make your card design!
  4. this is IMPORTANT. Apply your icon component that you have made into your card design, so you can actually change the icon that you want via properties
  5. Make that whole card as a Component,
  6. Finish!
You can now use your card component into your design and you can change your icon by selecting the icon inside the card instance and set which icon you want to apply in the Properties,
Hope this help!
