Component update from published library not reflected in file using library
  • January 29, 2025
  • 31 views
Derek_Hatfield
I’m having some issues when I make an update to a component in a published library, the update is not reflected in the deign file that is using the library.
I’ve closed the tab and restarted Figma with no resolution.
  • 2545 replies
  • January 30, 2025
Hi there,
Thanks for reaching out.
Can you please confirm that you've published the changes in the library and updated the instances where you've used the assets?
If it doesn’t work, could you attempt to "repair component connections" using actions?
If the issue still persists, could you reach out directly to the support team with a copy of your file: https://help.figma.com/hc/en-us/requests/new? Our support team will look into it.
Please make sure you use the email associated with your Figma account, include links to the file in question, and share access with support-share@figma.com. Don't worry, inviting us to view your file won't impact your billing.
Thanks!
Toku
Derek_Hatfield
Unfortunately the proposed solutions do not work. Perhaps our component is too complex with too many pieces to be able to keep up with the connection sync. ??
I’ll discuss with my team if emailing a file is an option.
Thanks.
