Rasmus_Polaszk
Jul 4, 2024 10:48 AM UTC
Component description on regular frame
Hi fellow designers,
I’m facing an issue with a Text Area I borrowed from the Polaris Design System. I’ve customized it, but a link/text remains attached to a frame that isn’t a component.
Does anyone know how this is possible and have suggestions on how to remove the link? I’ve looked everywhere and can’t seem to figure it out.
Thanks in advance!
Emmanuel8
Jul 4, 2024 4:17 PM UTC
It seems this is still attached because your parent component (as I’m seeing on the left side panel) is the “Textarea”. So, if this element “Container” is part of an instance, then the documentation persists, I assume. You can try to detach the instance (just do it for testing) and check in the layer “Container” if this persists.
Rasmus_Polaszk
Jul 5, 2024 10:47 AM UTC
If I detach the component “Text Area”, then the link is gone from “Container”. But the link does not seem to appear in the component description of “Text Area”, only for the “Container” (see picture).
Skærmbillede 2024-07-05 kl. 12.39.17
Funny thing is, if I detach the component and then create a new component, from that one, the link will reappear in the new component.
Emmanuel8
Jul 5, 2024 11:37 AM UTC
Weird…it’s really funny because, as you said, the “Container” is not an instance.
But, overall, is this a problem for you? Also…have you tried checking this in an account that has the UI2? Because this problem may be specific of the UI3. Maybe?
