Code-connect set up issues
Enzo
Hi,
I tried to install Code-connect following code-connect/cli/README.md at main · figma/code-connect · GitHub
I tried installing globally and locally @figma/code-connect but have the same issue.
Here is the issue I get after thefigma connect create "https://..." --token <auth token> command, and can’t solve it even with GPT:
I tried uninstall, cache clean, re-install, and still have the same issue. I’m turning crazy
Do you have any idea?
Enzo
  • July 16, 2024
any help? .
  • 4852 replies
  • July 17, 2024
Hey @Enzo, thanks for reaching out and so sorry for the delayed reply!
What Node version are you using? Can you check for any updates?
This might be a symptom of an incorrect Node version, because we require Node version 16 at a minimum (see here).
