Can not edit instance
Ayako
Hi I have a problem that I can not edit instance. It had happened sometimes, but I ignored that issue. It is time to solve…!
I created a component and copied it. Then I can not change element in instance. The instance looks being locked.
Here is the Figma file :https://www.figma.com/design/BN7TCfhatQdKdmfPgHGZnx/question?node-id=0%3A1&t=5g1hBDdrmdijxrpI-1
Thank you in advance for your help.
Ayako
  • 4710 replies
  • May 20, 2024
Ayako
  • 10 replies
  • May 20, 2024
Thank you @Gleb for quick response. Okay I misunderstood the function of the component.
I wanna ask you additional advice. In this case- creating a navigation bar with default/ active status, is the best practice making an component for each icon/navigation ?
Thanks in advance!
  • 4710 replies
  • May 20, 2024
No, you need to swap instance of the icon.
Figma Learn - Help Center
Ayako
  • 10 replies
  • May 20, 2024
@Gleb Thank you for the link! It is getting complicated though… I will try.
