Bulk define "Layer" component properties
Guy_Meyer1
I want to bulk add boolean properties to variants in the same way I can edit their name for basic properties (e.g., State=Default).
I’m looking to do the same thing for the layer property, which doesn’t support using the variant layer name convention to achieve the same effect.
Any suggestions for native Figma tools to achieve this would be appreciated. I’m open to plugins, but I’m coming up empty-handed.
  • 4707 replies
  • January 5, 2023
Are you looking for this magic button by any chance?
Figma Help Center
Guy_Meyer1
  • 7 replies
  • January 5, 2023
That button is magic, but unfortunately, it doesn’t work in this case. I should have clarified this part:
I’m trying to mass select the same layer within hundreds of separate variants to then apply the layer boolean property.
To be specific, I’m trying to make a customized version of the Phosphorus icons where the “DuoTone” layer in each variant set is a boolean toggle instead of a whole variant. My goal is to make all “stroke” versions (Light, Regular, Bold) have the DuoTone layer as a boolean option.
Osama_Turki
  • Active Member
  • 42 replies
  • January 5, 2023
You can create a variant property named Due Tone then select all due tone Icons and set the value True, while settings other to False. This will make the property variant as Boolean.
Guy_Meyer1
  • 7 replies
  • January 5, 2023
Is there a way to mass set a property named DuoTone? There’s like 500 variant containers 🙂
Osama_Turki
  • Active Member
  • 42 replies
  • January 8, 2023
@Guy_Meyer1 I am sorry I couldn’t get to you earlier
Select the main component then create a new variant property
The Select the required instances and adjust the value as required
