matko13
Sep 28, 2022 11:53 AM UTC
Boolean property message "not used within component"
Hi there, I have a problem with creating and applying a boolean property.
I have a button that is created with nested components. I create a boolean property on the top level of a component to show an icon-only button variant. Still, when I want to apply it to the variants, it’s not visible there so I get an error that says the property is not used within a component. Does anybody have a similar problem? Screenshots attached.
tank666
Sep 28, 2022 12:15 PM UTC
matko13
matko13Author
Sep 28, 2022 12:34 PM UTC
I found a different solution - in my case, instead of boolean property, It can be done by applying a true/false variant.
Matt_W
Dec 20, 2022 2:01 PM UTC
I have the same question/problem. The issue is that there is no intuitive way of applying the boolean property to a variant.
If there’s a help article for how to use this please can you add the link to it?
tank666
Dec 20, 2022 3:36 PM UTC
Nov 28, 2023 11:36 AM UTC
You have solved my problem with this practical short video ! Thanks 💛
Pavel_Pavlyuchik
Feb 20, 2024 8:30 AM UTC
Just select component instance inside your component and press at this Zalupka
Screenshot_4
Jul 1, 2024 4:42 PM UTC
Just create variant with values TRUE and FALSE, that fix problem!
Jul 15, 2024 9:00 AM UTC
Hey I had the same problem while makink variants and component properties.
First I used this “Boolean Property” But It didn"t work I dont know why.
then I used “Variant property” With true/false an it did work
can some one please tell me why boolean property was not working?
it just hide the layer/variant
Tony_Eneh
Jul 17, 2024 1:55 PM UTC
thank you. This short video clarified it for me
Andrew_Rodin
Dec 24, 2024 11:02 AM UTC
Who developed this feature isn’t designer, the Figma was the best instrument, but just only was… All mates say, that it’s become bullshit
