Hampus_Svallfors
February 7, 2024
Arrow Up/Down to select style from auto-complete has stopped working
Hi community!
This is tricky to explain. But sometimes the arrow up/down seem to simply move the Caret Position in the input field to the beginning or the end, instead of changing the selected item in the list. If I hover the list, the up and down selection starts to work again.
Feb-06-2024 17-18-56
Using arrow down to select from all auto-complete searching is deep in my muscle memory, as I’m sure many of yours as well, so this issue has become somewhat if a nuisance to me. I never realized how many times per minute I searched and selected a style or variable before this started not to work.
Could this be something with my trackpad, keyboard, computer etc. Or is it something anyone else also has experience?
y_tokuSolution
Thanks for the feedback and I shared these with our internal team. We cannot guarantee if it’s prioritized but we will let you know if there is anything I can share with you.
Let me merge into an existing one:
Thanks!
Toku
Hampus_Svallfors
February 7, 2024
Another GIF showing the caret just going back and forth inside the input field when I press arrow down/up:
Feb-06-2024 17-32-44
Hi there,
Thanks for flagging. I could reproduce the issue! I will share this with our internal team. can’t guarantee anything on our end, but I will give some visibility to our team for consideration.
Toku
Jacek4
have exactly the same issue. Working on the macbook pro 14 m1. It started about 2 weeks ago I guess.
Phil_Larsen
February 16, 2024
When typing in the styles search bar, I used to be able to tap the up/down arrow to navigate between the results in the search. Now those arrow keys go to the beginning or end of the text in the search bar. This requires me to use the mouse to click on the object I am trying to select rather than being able to use just the keyboard.
PasDee
February 22, 2024
fill-selection-nope
My issue is that whenever I type a search in to the fill selection panel, I cannot, for the life of me, navigate with up and down arrows anymore. This used to work all the time, at least for the last 2 years.
Instead of going through my search results, it just goes to pos1/end of text area.
This requires me to get my hands off of my keyboard and back to my mouse, just to select what’s like 20px below the text box.
Tab cycles through EVERYTHING EXCEPT the actual content of that panel. Really asking myself what this is about.
PasDee
February 22, 2024
Just created a new post since I could not find this one. Same issue here. Started around when you posted, still persists, drives me crazy.
Not even Tab is of any use.
Brian_Saunders
I am also having this issue and would appreciate if Figma could look into it. Weirdly the keyboard handling works when traversing some libraries, but not others. This is a big productivity killer for me as well.
Brian_Saunders
I’m also struggling with this issue and it’s taking me out of my flow. It only started within the last couple weeks and I hope it is fixed soon. For me the issue only happens when trying to navigate search results from a certain library.
Phil_Larsen
March 11, 2024
Any updates on this? It still messes me up
y_tokuSolution
Thanks!
Toku
