Vincent_Huss
Jan 23, 2024 10:59 AM UTC
Are the functions Node.width / height O(1)?
Hi !
I would like to know when i do node.width or node.height,
if within the Figma API, the retrieval of this information is O(1) or more.
in other words, is it precalculated, and available as a data to be just returned ?
or does this triggers some calculations involving loops over the children (and potentially recursive)
and if it does, is it internally cached to avoid recalculating it twice ? (if nothing was written in between)
thanks in advance for the insight !
Jan 24, 2024 5:48 AM UTC
H there,
Thanks for reaching out. I’m checking with our internal team, and I’ll get back to you if there is anything I can share with you!
Toku
Jan 25, 2024 5:41 AM UTC
Hi there,
As I checked with our internal team, we don’t do any recursive traversal to calculate the size. Why not always O(1)? When interacting with a node object, sometimes we need to make sure that that the node is in a “clean” state before reading its properties.
I hope it helps. We will keep improving with your feedback!
Toku
Vincent_Huss
Feb 11, 2024 6:37 PM UTC
Thank you very much for your answer and sorry for the super late reply,
so can i assume that if querying the width/height of a specific node 2 times in a row, the 2nd time will be O(1), it’s only if the user (designer) modifies the node or a child that it gets labeled as “dirty” and triggers some recalculations
Feb 13, 2024 12:24 AM UTC
@Vincent_Huss thanks for the reply! Yes, you can assume that getting the width/height should be O(1) most of the time.
I hope it helps!
Toku
