Adding images with original names
Jakub_Vlk
How to place image to Figma without any suffix - i need to have original unchanged names of them and figma adds 1 on end. Thanks 🙂
  • 4707 replies
  • April 30, 2021
I haven’t tested but this setting might help. If it doesn’t there is no other way. You can only batch rename all layers and remove the numbers by matching them with regex.
Figma search menu: Rename duplicated layers setting
Ricardo_Pitanga2
Disabling “Rename duplicated layers” had no effect on the name of imported images. They still receives “1” as suffix. The real issue is when I have a series of numbered images, in which case it crates confusion by adding another number at the end, becoming something like “file-name 1 1.jpg”, “file-name 2 1.jpg” etc.
  • 4707 replies
  • February 6, 2024
you can batch rename them (cmd + R) to remove the extra numbers
daken
  • 22 replies
  • September 7, 2024
By placing multiple images into Figma, this problem can be prevented.
