tank666
November 27, 2023
Add CODE_BLOCK, STAMP and HIGHLIGHTER nodes to the REST API
  • November 27, 2023
  • 306 views
Currently the following node types are not included in JSON output: CODE_BLOCK, STAMP, HIGHLIGHTER.
If you use the GET file endpoint, the JSON will not have any of the above nodes.
If you use the GET file nodes endpoint, you will get this output for each of the above nodes:
	"document": null,
	"components": {},
	"componentSets": {},
	"schemaVersion": 0,
	"styles": {}
Hi there,
Thank you always for your input. We really appreciate it!
Toku
