Unable to "clone' a document through the api
  • October 13, 2021
  • 432 views
Vincent_Koopmans
Hi Everyone,
I am investigating the possibility of migrating a Multibrand Design System from Sketch to Figma. But running into some issues.
The current setup I created in Sketch works as follows.
• I have a core library with color styles / textstyles / border radii / dropshadows and all the components used for web / ios and Android.
• I use a plugin called Puzzle Tokens to inject styles from sass into sketch.
• Per Brand I have a .SCSS file that contains brand tokens and Dark theme tokens as well as paths to imagery that get applied as well.
• I have a shell script that clones the core library and runs the plugin to apply the branded tokens to each version of the cloned file. We run it periodically.
• The result is every Brand library is a 100% clone of the core library but with the right branding and theme applied to it.
The issue I know see is:
From what I understand there is no way of duplicating a figma Document through the api, which would mean I have to keep track of changes in multiple libraries.
The Brand/Theme tokens I could manage through the awsome Figma Tokens plugin.
Is there any way of getting close to the workflow I’ve setup in Sketch?
Thanks 🙏
Be the first to reply!
