SF symbols disappear when I click on them
Natali6
Please help. I was added to existing project. When I open the file some sf symbol icons disappear. They also disappear when I click on them. How can I solve it?
Best answer by djv
Hey All,
These strange font issues are usually caused by conflicting font files across your team. This means that editors on a file are using different versions of the font with slightly different sizing or spacing which then affects the file each time it is opened by someone with a different version.
Our Help Center has more information about resolving this kind of issue: Manage conflicting fonts
We suggest that you have all editors remove these fonts if they are locally installed. Then, please ask all editors to install the same version locally. After doing so, you will need to restart Figma to serve the correct font version.
If this is affecting component appearance, you can also launch quick commands (cmd /) then use the “Regenerate all instances” tool to refresh all of your instances at the same time.
If it is affecting text or style appearance or settings outside of components, you can use quick commands to “Select all with same font” and then “Recompute text layout in selection.”
michelle_mugrabi
Hi! Did you find a solution to this? because I’m having the same problem.
Chris2
  • March 1, 2023
Anyone find a solution for this? We still have this happen any time someone with a non-mac computer opens a file with SF symbols in it.
Aaron_Kelley
My coworker is also having this issue whenever she opens docs that I’ve created
Lahiru
  • June 7, 2023
Same here! Has anyone found a solution for this? One of our developer experience this issue, he uses a Windows computer to open a file containing SF symbols. He is unable to see the symbols, so I have to update all designs to SVG icons 😦
Kateryna_Kamianets
the same is happening for me, this frustrating 😦
Kateryna_Kamianets
I tried installing SF Font )all possible styles) and it seems to have worked 🙌
  • 4751 replies
  • November 17, 2023
  • February 19, 2024
目前貌似仍然不会展示 SF Symbol 符号。
(最新的 Figma&SF Pro 字体)
  • February 19, 2024
  • 4751 replies
  • February 21, 2024
Hey All,
