Right constraint doesn't work in instance of component
Tema_Zimmer
Hi folks, I’m trying to use an absolutely positioned icon in the card component. I set the position to top and right, and it only works correctly in the main component. But in the instance, this icon is only fixed at the top.
How can I achieve the similar behaviour that I have in the main component in instances?
Best answer by tank666
I noticed that you used a boolean exclude operation and set the constraints on this object. Figma doesn’t handle this correctly in instances, so you need to wrap that object in a frame, and set that frame to the necessary constraints.
Tema_Zimmer
Tema_Zimmer
Ryan_52
  • Technical Quality Specialist
  • June 9, 2023
Hi @Tema_Zimmer Sorry to hear you’re having trouble! The forum is primarily managed by the community. Can you please reach out to the support team directly via this form for help: https://help.figma.com/hc/en-us/requests/new
Be sure to use your Figma account email, include these links to the file, and share it with support-share@figma.com so they can take a closer look.
tank666
Tema_Zimmer
@tank666 Thanks a lot! I wrapped this icon and it works just right!
  • July 11, 2023
