Remove White or transparent background in Figma
chitti_sri
Hi , Could you any one tell me short cut key or process to remove white background or transparent cells to get only image in Figma . Hope you understand the my problem .
ex img attached .
Thanks in advance
Best answer by tank666
tank666
  • 4873 replies
  • March 3, 2021
Menu ⟩ Object ⟩ Remove fill
Mac: Opt + /
Windows: Alt + /
chitti_sri
  • 4 replies
  • March 3, 2021
Hi tank, Thanks for your replay . After pressing shortcut key or Remove fill then image also invisible . Tried with this attached image and different images same result losing imaes also completely .
tank666
  • 4873 replies
  • March 3, 2021
Do you want to remove the background from the image? Then you can use a mask or plugins, for example, Remove BG.
Figma
chitti_sri
  • 4 replies
  • March 4, 2021
Hi again , Thanks for response . May i know how can you remove the bg in attached image. You given good plugin but in designeing that plug in pricing very high even in learning .
tank666
  • 4873 replies
  • March 4, 2021
I do not see your attached image.
Figma also has a global search where you can find any other plugins for removing backgrounds from images.
chitti_sri
  • 4 replies
  • March 4, 2021
Hi , I am attaching images links here, Actually removing bg for this kind of very easy but i forgot how to do that . If i paste below images i can see these bg white or transparent cells .
thanks in advance.
tank666
  • 4873 replies
  • March 4, 2021
chitti_sri
  • 4 replies
  • March 4, 2021
Perfect , thanks for sharing
Bob_Dilan
I hate doing the background image removal, it’s too hard.
Carol_Ovens
Personally, I found blogs from figma to be quite useful. You can find them on their website.
But since you’re looking for an image background change, I would suggest you to use other tools like erase.bg and slazzer. They are easier to use.
Yes, several free websites offer the removal of photo backgrounds. I would suggest trying erase.bg as it is the safest free website which I have come across.
Remove background from images of humans, animals or objects and download high-resolution images for free. You can also edit photos as you like. It also supports developers in removing image backgrounds through API.
Carol_Ovens
Hi bob, it’s not hard. Let me suggest to you an online tool that will remove background in a single click. I would advise using new-age technology products like http://erase.bg for this task because it is easy to use and gives quick results. You can go to their website and use it for free. It takes 5 seconds to convert an image using http://erase.bg 🙂
I prefer this product over Adobe photoshop whenever I need to remove the image background. Check out their blogs on Free background removal – erase.bg
Bijutoha
  • 4 replies
  • June 2, 2023
Here are some additional tips for removing backgrounds in Figma:
  • If the image has a complex background, you may need to combine the Remove BG plugin, the Magic Wand tool, and the Eraser tool to get a clean result.
  • If the image has a lot of small details, you may want to zoom in to get a better view of the background.
  • If you remove a transparent background, you may need to set the Fill colour of the image to fine before exporting it.
But in my case, Whenever I need to erase the picture backdrop, Adobe Photoshop is the program that I turn to most often.
Here are some of the advantages of using Adobe Photoshop to remove image backgrounds:
  • Powerful tools: Photoshop offers a variety of powerful tools that can be used to remove backgrounds, including the Quick Action tool, the Magic Wand Tool, and the Pen Tool.
  • Precise control: Photoshop gives you precise control over removing the background. You can use the Magic Wand Tool to select the experience with a high degree of accuracy and the Pen Tool to create a vector mask that will hide the experience with precision.
  • Transparency support: Photoshop supports transparency, so you can save the image with a transparent background. This allows you to place the image in any location that you want.
You’ll find a comprehensive guide on removing background paths at https://pathedits.com/blogs/tips/tagged/background-removal if you want to learn more.
