Release Notes (April 14)
Andrew_Chan
Hey folks!
Some of last week’s patches were moved to this week. Here are the release notes:
  • You can now override existing “change to” interactions on instances or add new ones.
  • UI improvements for the “change to” interaction panel to make it easier to select a destination variant.
  • Fixed stutter during hover interactions in some large prototypes
  • Various performance improvements for all interactive component interactions
  • Fixed bug where image fill overrides would go blank momentarily when changing interactive component instances in presentation mode
  • Fixed emojis disappearing when changing interactive component instances in presentation mode
As always, your bug reports and feedback are appreciated. You can reply to this post directly or start a new topic in the forum!
nwhitson
  • 6 replies
  • April 16, 2021
Thank you so much for keeping us all updated! Really loving interactive components and what we’re now able to build 🙌
Question, any updates/movement on this bug? Text Override doesn't work on nested variants with interactive components
We have some many components like this, using nested interactive components to create mutually-exclusive selections, that I’m getting nervous about whether or not it will actually be supported or if we’ll need to plan on sticking with the existing system of creating complex prototyping logic trees to handle things like Radio Button groups.
(Also, not sure if it’s clear from that other thread, but ALL overrides don’t seem to work, not just text)
Shane
  • 74 replies
  • April 16, 2021
I second the post from @nwhitson, I’m holding back on architecting out a design system based this point. It would be good to know if nested overrides are going to be supported so we can proceed one way or another.
Andrew_Chan
  • Figmate
  • 40 replies
  • April 21, 2021
Hi @nwhitson - that’s definitely a bug! Thanks for the report. Nested overrides should indeed be supported. We’re looking into it.
Remus_Baltariu
I’m actively viewing the Release Notes on a daily basis just to see what are the updates. Keep it up, people! You’re doing an awesome job! 👏
Shane
  • 74 replies
  • May 13, 2021
That makes two of us! 😃
Asaf_Ben_Oved
Hey Folks, the last update was in April. It’s now August. Any chance you guys are cooking bug fixes and improvements? I’m really hoping to start using this feature officially. Something that I’m not doing since there’s plenty to be fixed on this. It’s a great feature no doubt.
Helium
  • September 13, 2021
Reinforcing Asaf’s question above. We’re now in mid-September and no updates since April. I’m just curious to know if there’s any chance this feature is coming officially to Figma anytime soon?
I’m about to start a couple of big projects and it would be amazing to use interactive components in them. By the way, interactive components is a great feature and kudos for all the amazing work behind it! 👏
J_Yun1
  • 12 replies
  • September 15, 2021
Pleeeassseee add multi-state function within a single element instead of having to “change to” for each state.
Joy
  • 16 replies
  • June 28, 2022
This problem seems to have reappeared again, and it needs to be repaired.
