Prevent object from being added to Auto Layout group while dragging by holding down modifier key
Olle_Stromdahl
Quite often objects tend to end up in an auto layout group by mistake.
It would be nice to be able to hold down the shift key so I can place an object ABOVE an Auto layout group.
Best answer by Gleb
You can hold Space bar.
  • 4708 replies
  • February 4, 2021
Olle_Stromdahl
Kind of works! But space bar does not work when it’s already over the group. It does not snap out it. I have to drag the object far away from the group and then hold down space and go back. But, better than nothing!
  • 4708 replies
  • February 5, 2021
Yes, their implementation is very strange.
Svarry
  • 27 replies
  • March 9, 2021
Thank you Gleb!
Jonhenry_Righter
Piling on here. I’d be surprised if people want this to happen (dragging into a frame) often enough to make it default behavior.
The spacebar trick is finicky at best. Please allow us to disable this feature. Or, conversely, only activate dragging into a frame when the space bar is pressed. This actually slows me down on a regular basis.
Ignacio_Barbano
Figma is awesome and thanks for all the hard work you’ve put in it!!! It’s awesome that this is one of my only struggles with the product so far 😃 as it is pretty minor!
Still, it’s been a while now since I started using Figma and this detail does not match my expectation for dragging, I’m always clicking around buttons on the keyboard sort of hoping for one to change the dragged element’s interaction without success.
Thanks again!
CoreyLewis
Completely agree! In fact, this feature should’ve been implemented in reverse. If you hold the spacebar and drag, only then should Figma enable you the ability to drop a layer into an Auto Layout group, not the other way around. Any chance this adjustment can get integrated very soon??? Thanks for the amazing product Figma!!! Just changed from Sketch 2 months ago and it was the BEST decision I ever made, an even better decision than the day I chose to switch from Photoshop to Sketch!!! 😄
bondarangelina37
Please help, if I press spacebar and try to drag an element, it doesn’t move! At all…
Ozzy
  • July 21, 2022
+1. This should be an opt-in feature. I hardly ever try to drop something inside another component. Holding spacebar all the time is a poor UX. @Figma_Support – Please fix this.
Parker_Hutchinson
+1 to making this opt-in. This decision has boggled my mind. When dragging you should hold a modifier key to place it into the frame not the other way around. figma such a frustrating application at times. Very counter-intuitive coming from any other tool, uniqueness to a fault.
Ekom
  • 4 replies
  • September 6, 2022
Same. Have you figured it out?
  • 4708 replies
  • September 7, 2022
Start dragging first, then hold space. This behavior is very poorly implemented in Figma.
Ekom
  • 4 replies
  • September 7, 2022
Gets worse. It just comes to halt
  • 4708 replies
  • September 7, 2022
If it’s already inside of an auto layout frame, it wouldn’t move because it is not being moved to a different group and within the auto layout you can’t move objects: auto layout controls their position.
Ekom
  • 4 replies
  • October 15, 2022
I ensured the object isn’t in auto layout. Still the object isn’t moving when the space bar is pressed
  • 4708 replies
  • October 15, 2022
Is it moving when the space bar is not pressed? Send a video
Emin-S
  • October 19, 2022
This implementation is not very well done in my opinion.
To get this to work you have to:
  • Click and hold the item you want to move
  • Press and hold space bar
  • Drag to the position you want
If you try any other order, this does not work. The main issue for me is when you already dragged it inside an auto layout by accident and then press space, it does not jump back to the original layer.
Duplicating (option+drag) works in any order you want. You can press option before or after dragging to duplicate. And when you release option while dragging it stops duplicating. I would expect this interaction (prevent nesting) to work in the same way.
The other way mentioned that could solve the problem as well is to opt in instead of opting out while holding space.
Dario_Martini1
Also, it is not possible to duplicate an object and ignore Auto Layout groups while dragging (e.g. option-spacebar-drag is not allowed).
Ana_Karen_Aguirre
+1 please make it something that you allow to happen not something by default (adding objects to auto layout group)
Saro
  • 8 replies
  • September 5, 2023
Huge issue, makes Figma very annoying to work with.
If space would work when already inside and snap back out, it would be OK
Just want to join those in favor of reversing this behavior. The current implementation really detracts from an otherwise solid tool.
JoQe
  • September 20, 2023
I mean I’m ok with holding a shortcut key… but spacebar is already used for panning in the screen, so the ordered in which we need to do this action is weird and prone to errors. I would be glad even if I have to hold three buttons, just make it a key combination that is not used for something else 😕
JoeM
  • 8 replies
  • December 28, 2023
How is this still an issue?
